Driven wheel speed
Driven wheel speed
Postby greenamex2 on Mon Aug 08, 2016 11:03 pm
Probably a dumb question but I'll ask it anyway.
If I don't have any speed sensors on my driven wheels, will the M1 calculate driven wheel speed from RPM/gear ratio/final drive ratio/wheel diameter?
And assuming it can, and I have speed sensors on my undriven wheels, can I use the traction control included with teh GPR package?
Just checking before I finalise some bits on the wiring loom.
Thanks/
greenamex2
Re: Driven wheel speed
Postby David Ferguson on Tue Aug 09, 2016 3:12 am
No. The GPR wheel speed channels all come from sensors (or sensor data provided over the CANbus).
It's always a good idea to make provisions in your wiring harness for wheel speed sensors.
Postby greenamex2 on Tue Aug 09, 2016 7:55 am
So much for that idea!
Looks like I need to shuffle around inputs on my CDL3 then.
greenamex2
Postby Stephen Dean on Tue Aug 09, 2016 9:54 am
From the M1 Help.
You can use the calculated wheel speeds for TC, it would be better to have sensors if you can. You also need to ensure that your Gear Ratios are correctly setup to generate the Vehicle Speed.
Vehicle Speed.PNG (54.45 KiB) Viewed 14014 times
Postby David Ferguson on Tue Aug 09, 2016 2:34 pm
I don't know how I missed this. In fact I'm still struggling to find it in the GPR Feb 2016 package 1.07.0002
What is the exact channel name (Vehicle Speed Estimated?)
Thanks for the enlightenment!
Postby Stephen Dean on Tue Aug 09, 2016 2:45 pm
The Help Location is Vehicle Speed, it's also visible from the top level of Vehicle.
Postby greenamex2 on Tue Aug 09, 2016 7:31 pm
Thanks all, that was how interpreted the help file but wasn't 100% sure.
Will have to have a think about priorities.
greenamex2
