I'd need an injector's latency/batt values for an Mx00 ecu and I found there is an M1 mtccal file of the same injector:
how to extrapolate the values I need?
SDean wrote:Hi,
If you send an email to support @ motec.com.au with the part number for the injector, I can provide you with the correct values for the Mx00 ECU's. You shouldn't use the M1 Data for the Mx00 ECU's as we calculate the data differently.
Users browsing this forum: No registered users and 27 guests
