motec m150
motec m150
Postby claudiumxg on Sat Nov 02, 2013 4:37 pm
I am intrested in buying a m150 ecu for my evo 8 project. In spec sheet it states only peak and hold. The m150 gtr pakage states that you can use id1000 injectors and id inj are all high impedancea aka saturated. My question: doea the m150 run saturate injectors also or not? Because 99.9% inj on the market are high impedance and if m150 only does low i.pedance than is problematic
claudiumxg
Re: motec m150
Postby jalai on Sat Nov 02, 2013 11:20 pm
Yes, it is possible to use Hi-impedance injectors too.
jalai
Re: motec m150
Postby claudiumxg on Sun Nov 03, 2013 5:25 am
On any m150 firmware?
claudiumxg
Re: motec m150
Postby stevieturbo on Sun Nov 03, 2013 7:41 am
Surely if you are buying the ecu for your chosen project, Motec will enable whatever features you need ?
I would find it impossible to believe that it wont run high impedance injectors, given they are now the performance industry standard
stevieturbo
