M130 SeaDoo
M130 SeaDoo
Postby ad4342 on Mon Apr 01, 2013 6:22 am
When I connect the M1 with the LTC 4.9 with bosch lsu 4.9 and open the LTC manager the laptop can't find the lambda sensor. It keeps searching. Lambda is not working.
Do i need to buy lambda option for M1 in addition to buying the LTC 4.9 unit?
How do I verify that i have option 2 logging on my M1, i paid for it.
Your help is appreciated.
ad4342
Re: M130 SeaDoo
Postby YuriK on Fri May 17, 2013 11:27 am
With logging level 2 you should have 1 configurable logging set with up to 200 channels (including diagnostics) and max sample rate of 200Hz.
Regarding the Lambda sensor, it is possible that your LTC is not configured with 500Kbit CAN bus (by default they come with 1Mbit CAN bus). To check this you'll need to download and install LTC manager and connect the LTC (using UTC) to your laptop. Or the simpe way - take the ski to your dealer :)
Regards!
YuriK
