D153 D1 Receive DBC
Place to discuss Formula SAE projects
D153 D1 Receive DBC
Postby barn36 on Sat Mar 04, 2023 11:34 am
My formula team has built its own VCU/data logger this year but still wants to use the D153 as our dash display. We are having trouble finding a way to send/receive switch inputs from the dash to our data logger. Is there a way I can obtain the DBC file for the D153 D1 Receive messages?
Thanks!
barn36
Re: D153 D1 Receive DBC
Postby David Ferguson on Mon Mar 27, 2023 11:10 am
While there isn't a DBC file, you can use the C125 or C185 Dash Manager and configure CAN comes for D1 Receive, and that will have all the info you need, just click the edit button. Basically there is a compound message on CANID 0x0E9,with 0-3 in the first byte as a index/counter.
Postby adrian on Tue Mar 28, 2023 8:38 am
Display Creator allows you to configure your own transmit messaging, you can set it up to send the switch information however you want.
If you want to use the default transmit then below is a dbc file.
D1 Receive.dbc
(1.8 KiB) Downloaded 8855 times
Return to Formula SAE
