Denso Fuel Injector Calibration
Place to discuss Formula SAE projects
Postby aryno on Wed Nov 17, 2021 2:36 pm
This year our formula team is switching to a Yamaha R6 engine, and are hoping to run the stock injectors. I can see in the Initial Setup page of M1 Tune that our stock injectors (Denso 0640) are precalibrated. Is selecting them in this menu all that needs to be done for the initial setup of these injectors, or is there other information that will be needed?
aryno
Re: Denso Fuel Injector Calibration
Postby Stephen Dean on Wed Nov 17, 2021 4:14 pm
Yes,
If you select the injectors (or any other calibration) from the drop down menu, then the required data is applied to the calibration.
Return to Formula SAE
