How to start with the traction control
Place to discuss Formula SAE projects
Postby krommel on Tue Feb 15, 2011 9:31 pm
This year our team uses the CBR600 f4i, and we want to use the fuction ---traction control. I want to know what do we need to use this fuction? What kind of wheel speed sensor or other facilities do we need to buy? We do not have ABS, so we can just use this by using cut down the fuel or ignition.
Thank you
krommel
Re: How to start with the traction control
Postby Motorsport Eng. on Wed Feb 16, 2011 12:50 am
Hi krommel,
motorcycle traction control it is a wide matter and M800 it is a ideal choice to support both a simple system with less parameters, or a complex one with more numbers,even when it will be developed.
Speed sensor is important and them quality as well, but M800 TC could use also other inputs.
It is better if you read the help (press F1) at beginning.
We have experience of that, so we can try to help.
Send us your email in PM.
Best Regards
Andrea Torniero
www.motorsportengineering.com
Motorsport Eng.
Return to Formula SAE
