M84 nearly maxing out
Hello everybody,
the M84 on my R33 GTR is nearly on the edge of its capabilities.
All the outputs are used and inputs too.
I need to add coolant pump control and PWM control for a DHB or a SSR for my twin 044 pump system. Maybe I will need a flex fuel sensor too in the upcoming future to run E85 mixed with pump 100 and lord knows what else.
I actually have a map with 4 boost steps running pump gas + toluene 5%, I would also like to have a switch to let me choose between 2 maps (at least 2 different ignition advance tables) to let me drive both pump gas or toluene mix.
I know that M84 doesn't have multi config as the M800 but maybe there's a trickery to do that.
That said my doubts are between buying an expander (expensive expander
) for the M84 or upgrading the ECU to another model.
Luca
Luca
