Turbo boost control
Sun Jun 19, 2022 3:09 pm
by stainless1
I am adding boost control to my M84 used on a Bonneville Land Speed Car.
Can I ground the control solenoid and use Aux 1 for voltage or should I put 12v on the solenoid and use Aux 1 to control ground. Does it matter? Can it be done either way?
Re: Turbo boost control
Mon Jun 20, 2022 2:34 am
by stevieturbo
ecu outputs ground trigger.
Put 12v to the solenoid, and then the other wire is the ecu trigger.
Mon Jun 20, 2022 10:22 am
Wire it as Stevie said, it is the better option to have the ECU providing the ground than the power for solenoids and similar.
Mon Jun 20, 2022 10:26 am
by stainless1
Thanks, in trying to set it up on the computer I saw that Aux 1 can't do PWM with volts, only ground. Looking for a switched power to tie into and will put the ground lead on Aux 1 or Aux 3.
