Using AEM Wide Band X-Series Lambda Sensor with m84
Hi folks
I am switching from an OMEX ECU to a Motec m84. The old setup used AEM X-Series Wideband Lambda sensors (P/N 30-031N). The sensors put out 0-5v with a calibration table that they provide. I'm trying to figure out the correct setup for the m84. I set the Lambda Sensor Type to 0 for the two sensors and entered the voltage-based calibration table in the Input Setup screen. Do I wire the analog voltage leads for the two sensors to LA1S (B25) and LA2S (B12) and the two ground leads to Sensor 0V (B16)?
Thanks for the help!
Kurt
Kurt
