BIRKIN 7 with KAWASAKI ZX14R - HELP :) Base MAP required
Hi Everyone,
My little project is a Birkin 7 ( Lotus 7 replica) with a Kawasaki ZX14R motor. Its sort of a MID MOUNT set up with the motor next to me driving directly onto a Subaru R160 diff.
If it doesn't understeer to much it should be fun... Gonna start NA, if its toooo slooooowww it'll get a TURBO
I was wondering if anyone has a base MAP for me to start with? Some assistance with setup to start would be greatly appreciated.
SET UP:
M84 - Single Lambda
PDM15
Stock ZX14R Motor
Stock sensors used
Stock injectors and Coils
Secondary Throttle Flaps removed
I think I have the base setup about 80% correct but Im getting a Ref/Sync - NotSYNCED when I crank it over.
Im using the #65 Ref/Sync mode but I have no idea what the other Ref/Sync setting should be?
FYI Kawasaki use a MAP sensor to measure vacum on cylinder #1 to start the sync process - if im not mistaken...
Thanks in advance
Oscar
South Africa
SET UP:
M84 - Single Lambda
PDM15
Stock ZX14R Motor
Stock sensors used
Thanks in advance
Oscar
South Africa
