BMW E36 M42 Startup - REF/SYNC
Sat Oct 30, 2021 6:29 pm
by mick41zxr
Setting up a BMW E36 318is (M42).
Having trouble getting the engine to Sync.
Able to test clean spark & injectors. Getting a clean RSC file.
- REF/Sync
- RefSync-Capture.JPG (363.52 KiB) Viewed 15330 times
I believe I have CRIP set ok
- CRIP
- CRIP-Setup.JPG (45.02 KiB) Viewed 15330 times
Does anyone have any suggestions.
Thanks,
Michael
Re: BMW E36 M42 Startup - REF/SYNC
Sat Oct 30, 2021 6:32 pm
by mick41zxr
I believe this to be the CRIP Setup
- M42 Crank Trigger.JPG (149.38 KiB) Viewed 15329 times
M84 file to see if I have made a mistake.
- error
- 20211030_150018.jpg (734.5 KiB) Viewed 15325 times
Any help appreciated.
Thanks,
Michael
Sun Oct 31, 2021 8:03 am
by GWRMOTORSPORT
Hi Michael, had a quick look at your ECU file and the ref & sync mag levels are all 9.5v,
they need to be set to approx 1/3 of the peak voltage at various RPM sites,
From the ref sync capture which seems to be at about 310 rpm I would use ref 1.3v and sync 1.2v
set the whole mag tables to this, it should sync up and start and then do some more captures and work out
the mag levels. Also the trigger wheel looks like its either running out of true or is out of shape,
the constant dip in the ref voltages just before the sync signal needs possible looking at.
Hope this helps
Regards
STEVE
GWR MOTORSPORT
PM if you need more help
Mon Nov 01, 2021 8:27 pm
by mick41zxr
Thanks Steve,
Changed Mag Tables & startup up straight away.
Much appreciated.
Michael
Fri May 13, 2022 5:57 pm
by muigandy
Thanks for trying to help!
