M84- 4 CYLINDER, 4-STROKE, SETUP SEMI SEQUENTIAL
Hi
I use M84 on a 4-cyl 4-stroke engine, which has no camshaft signal.
SETUP:
Number of Cylinder: 24
crankshaft signal: 60-2
REF / SYNC Mode: 8 (2 Missing teeth once per cycle)
Firing order: 1-3-4-2
Number of coil: 2
Wiring Ignition:
IGNITION 1: (CYL: 1 AND 4)
IGNITION 2: (CYL: 2 AND 3)
WIRING FUEL INJECTOR:
INJECTOR 1: CYL 1
INJECTOR 2: CYL 3
INJECTOR 3: CYL 4
INJECTOR 4: CYL:2
I was reading in this post: viewtopic.php?f=47&t=2689
I understand that in this mode (8) works in group fire (SEMI-SEQUENTIAL)
The injectors fire 2 times every 360º.
Question:
In what order do the injectors fire: Group 1: CYLINDER 1 and 4 or 1 and 3?
Group 2: CYLINDER 2 and 3 or 2 and 4
The injector duty cycle correspond every 180º?
Thanks, regards!
SETUP:
Number of coil: 2
Wiring Ignition:
INJECTOR 1: CYL 1
INJECTOR 2: CYL 3
INJECTOR 3: CYL 4
INJECTOR 4: CYL:2
Question:
Thanks, regards!
