Configuring a Hitachi Idle Control Valve
Hi
On my Ford small block v8 controlled by an m84 ECU I have an Edelbrock 3878 Throttle Body which comes with a "Hitachi Linear IAC Motor (Pulse Width Modulated)" idle control valve. I have the engine running fairly well but skipped configuring the idle control valve built into the throttle body since I couldn't figure out where to find the configuration parameters. Is such a valve a fairly standard control valve for that you'd have settings for? I have no other info about the part number of the control valve unfortunately. It has two input leads - +12V and a PWM input.
Thanks,
Kurt DelBene
Thanks,
Kurt DelBene
