trigger setup of comaro engine
Im working with project Comaro SS (LS3) engine 2012 thats swap and installed with Nissan and tuned by M84 ECU the engine is running but I need to be sure that the trigger setup is correct
ref/sync mode 17
crank ref teeth 60
tooth ratio 50
crank index position (CRIP) 67
ref sensor type 1
sync sensor type 1
sync trigger voltage 0.5
Im not sure about the crank index position because LS engine dose not have timing mark but the engine run without problem but I'm scared from (CRIP) angle
ref/sync mode 17
crank ref teeth 60
tooth ratio 50
ref sensor type 1
sync sensor type 1
