dwell time and injector dead time of LS3 engine
Postby EagleEyeMotors on Sun Nov 15, 2020 10:27 am
I have project on swap LS3 (comaro orignal engine 2013) , that connected to motec m84, I have connected the ignition on waste spark. my qustion is what is the setup of ignition and injectors ( dwell time and injector dead time )
EagleEyeMotors
Re: dwell time and injector dead time of LS3 engine
Postby Stephen Dean on Mon Nov 16, 2020 9:06 am
For us to be able to provide that information you will need to provide the manufacturer name and part number of the injectors and coils as this is how we catalogue this information.
Postby EagleEyeMotors on Thu Dec 17, 2020 4:28 pm
Part number of injector 80527
Part number of coil 12611424
EagleEyeMotors
Postby EagleEyeMotors on Thu Dec 17, 2020 4:33 pm
SDean wrote:Hi,
I include it in the post
EagleEyeMotors
Postby greenamex2 on Thu Dec 17, 2020 5:54 pm
Manufacturer names?
greenamex2
Postby Sean on Thu Dec 17, 2020 10:21 pm
They're oem GM/Delphi part numbers, I believe.
Sean
Postby Stephen Dean on Fri Dec 18, 2020 8:54 am
See the attached calibrations.
The only match that I have for the injector part number is for a FAST brand injector.
80527 Customer sheet.xlsx
(175.69 KiB) Downloaded 1233 times
LS3 12611424.xls
(2.25 MiB) Downloaded 1338 times
Postby EagleEyeMotors on Sat Jan 02, 2021 9:03 pm
SDean wrote:Hi,
in motec m84 there is voltage and fuel effective pulse width only there is no differential pressure how i can apply the table?
EagleEyeMotors
Postby David Ferguson on Sun Jan 03, 2021 4:11 am
Just use the voltage axis, for your fuel pressure setting.
Return to M84 ECUs
