depo windband meter gauges
depo wind band meter gauge use BOSCH 4.9 windeband meter that provide analog output that can connected to standalone ECU
analog output wire harness instruction for depo windband gauge
black - engine ground ( gose to ground do I have to connect it to ECU ground?)
brown - wideband analog output 0-5v ( were I can connect this one ?)
green - narrow band meter 0-1v ( were I can connect this one ?)
motec m84 has
pin 25 - lambda 1 sensor input
pin 26- lambda 1 pump current (this one for what exactly )
how I connect my LSU 4.9 BOSCH sensor were I connect brown and green wires ?
motec m84 has
