Unable to connect to ECU
Postby shaunsizen on Wed Oct 28, 2020 12:18 am
Hi
Wonder if anyone can help, I am unable to connect to my M84 ECU on the GT40 I am building, simply says No ECU Connected. I know the UTC CAN USB adaptor is good as my loom guy checked it plus he checked my ECU.
So I have
Got power and ground on the correct pins
Unplugged all the sensors
Downloaded the latest USB drivers and installed
Tried a laptop and a Windows tablet, both Win 10 laptop is 64 bit
Nothing, any ideas?
Should I be able to see the USB CAN adaptor as a USB device when connected to the laptop as I cannot, it's in the USB 3 socket plus have tried the USB 2
When I plug it in I can see it as a USB Controller in the Device Manager screen and if I remove it disappears so looks to be working as a driver should.
Cheers
Shaun
shaunsizen
Re: Unable to connect to ECU
Postby David Ferguson on Wed Oct 28, 2020 3:18 am
You probably need to download the "Utilities" installer, and install the Windows 7 & later driver for the UTC.
Here is a link, but it's on the Software Downloads page (at the very bottom).
https://www.motec.com.au/filedownload.p ... docid=3739
Postby shaunsizen on Wed Oct 28, 2020 3:43 am
Cheers David, spent a very wet day here in the UK doing some more digging, I found out that the pins 4 and 5 on the DIN plug had been wired the wrong way round, not sure how but once swapped it fired up no worries, all I have now is an error on a LA sensor c-6 which looking is the ECU shutting down for safety mode, wiring I think is fine (bit who knows) and I tried swapping the other LA sensor but to no avail. The only thing just dawned on me as I typed this was my map may not be for a dual sensor which was an extra, I'll check that!!
Cheers
shaunsizen
Postby Stephen Dean on Wed Oct 28, 2020 8:54 am
You will get the C-6 message on the Lambda sensor if the engine is not running. This is normal operation, if it doesn't clear when the engine is running then you have an issue with the Lambda control.
Postby shaunsizen on Wed Oct 28, 2020 11:22 pm
Cheers Stephen
shaunsizen
Return to M84 ECUs
