Gear Change Setup: Cut Mode 1
Postby TonyS on Thu Jan 30, 2020 5:45 am
I've searched the forum to no avail.
Could someone please explain the logic when using Cut Mode 1. I sprint race a Westfield with a Hayabusa motor and I'm struggling with flat shifting using Cut Mode 2 (not shifting gear, or hitting neutral instead of second gear after launch). I can't get my head around the modes description "Delay from next gear stable" ?
Cheers
Tony
TonyS
Re: Gear Change Setup: Cut Mode 1
Postby Stephen Dean on Thu Jan 30, 2020 8:27 am
I have attached a Training Note that explains the process of the Gear Change Ignition Cut system in the Mx00 family of ECU's.
CTN0004 Gear Change Ignition Cut.pdf
(523.12 KiB) Downloaded 1051 times
Postby TonyS on Mon Feb 03, 2020 11:59 pm
Invaluable Stephen, thank you
Tony
TonyS
Return to M84 ECUs
