How to calculate a baseline for IJPU
Hi!
After figuring out trigger setup, we got the car to start.
It stops after 2sec, and we've tried almost everything, adding fuel, in small and big amounts. Leaning out, nothing seems to help, to keep it running.
I guess it only runs on the priming pulses we give it by throttle blip through "Stopped Injection".
Motor:
BMW S14B23, stroked and bored, 2900ccm.
NA rallycross motor from Köhler Racing,
high compression, big custom cams, custom pistons, staged injection.
approx 385hp @ E100. (Prevoiusly ran M48)
How do I proceed to get the right amount of fuel, to at least keep running.
I copied IJPU, fuel main table, cranking corrections, post start corrections, etc from the M48 to the M84, but it seems to be way lean. But if I add fuel, there is no difference. Event when double the IJPU (from 20 to 40mS) and adding fuel in main table.
Is there someone here who can compare these 2 maps for me, to see where I'm off?
Motor:
