Inj and Ign voltages drops
Postby acca on Thu Jun 13, 2019 12:59 am
Hello
I have a question about Inj and ign voltages logging, as one can see in the picture, those voltages are not constant.
Is that normal please ?
image ign inj volt.PNG (53.14 KiB) Viewed 9483 times
acca
Re: Inj and Ign voltages drops
Postby Stephen Dean on Thu Jun 13, 2019 2:38 pm
I wouldn't be concerned about the way that the data traces look, as these can be changed a large amount based on the sample rate of the channel.
This is my ignition voltages logged at 100hz when the engine is idling at ~1000rpm. The missing Cyl 4 is because the event happened between sampling points, if I logged the channel at a higher rate I would have most likely have gotten these captured.
Ign Voltages.PNG (17.22 KiB) Viewed 9468 times
This is the same data with differing filters applied.
Ign Voltages Filtered.PNG (14.35 KiB) Viewed 9468 times
I have filtered Cyl 1 to the equivalent of 1hz logging, Cyl 2 to 2Hz, Cyl 3 to 5Hx and Cyl 4 to 10Hz.
Postby acca on Thu Jun 13, 2019 5:10 pm
Ok, so it's hidden by sample rate !
acca
Postby David Ferguson on Fri Jun 14, 2019 2:39 am
Nyquist to the rescue.
https://whatis.techtarget.com/definitio ... st-Theorem
Basically if you want to make sure you capture the details of a signal that can change at frequency X, you have to sample at 2X the frequency.
The diagnostic voltages for Injectors and Ignitions can really only be used to determine if they seem to be stuck high or stuck low, as you would need to sample at 20khz in order to see signals to resolved to the nearest .1ms
Return to M84 ECUs
