Question about relay behaviour
Hello
I have intermitent engine cuts looking like misfires
This problem can occur suddenly and disappear during many days so it's reason is particularly hard to identify
About that problem, i was checking my ignition configuration in motec settings, if i change ignition type from 1 to 2, the general relay "clicks" and the ECU restarts.
The same thing happens if i plug osciloscope plugs to the coil inputs (ignition module outputs).
This relay provides +12v to the car when turned on.
is that a normal behaviour ? Can it indicate a faulty relay ?
