Questions about SYNC errors
Postby acca on Thu May 16, 2019 6:21 pm
Hello
I use a Motec M84 for a monocylinder Shell eco marathon engine (25cc)
It's equiped with an inductive sensor for REF (flywhell 24-2 tooth) and the same for SYNC (placed over admission rocker)
I have two questions about this configuration.
Is the SYNC signal only used on engine start ?
Why do i have a SYNC error when stopping the engine ? I stop it by triggering a DUAL RPM limit.
acca
Re: Questions about SYNC errors
Postby MarkMc on Tue May 21, 2019 5:55 pm
The sync sensor is used to start the engine and the ECU will use it if it is there whilst the engine is running. What exact error do you have when the engine is stopping and to be very specific do you get it as it is stopping or when it has come to a stop?
Postby acca on Tue May 21, 2019 6:42 pm
Hello
You can find a screenshot showing erros during stop in attachment
screen sync errors.png (64.23 KiB) Viewed 10725 times
acca
Postby greenamex2 on Tue May 21, 2019 7:48 pm
What is the air gap on the sync sensor?
greenamex2
Postby acca on Tue May 21, 2019 7:57 pm
There is 0,5 mm gap
The sensor is given for 1mm distance (https://fr.farnell.com/schneider-electr ... dp/2455538)
acca
Return to M84 ECUs
