Lambda sensor calibration and closed loop lambda
Hello
I have a Bosch LSU 4.9 Lambda sensor.
I'd like to use it to perform closed loop calibration.
I have installed it following the Motec document https://www.motec.com.au/filedownload.php/?docid=3525
So i choosed Calibration "#38 Lambda internal LSU or NTK", but with this calibration, closed loop doesn't works (Lbda1ctrl is always off). I have to choose "#40 Lambda Bosch wide band meter" to make it work.
But with this choice, is the Lambda value correct ?
Is that choice important if i make an "air calibration" ?
