How to set up the M84 two stroke engine
Postby xiaoyaowangdaren on Fri Feb 01, 2019 6:46 pm
I want to know how to set the parameters of the two-stroke engine in the M84 ECU to start, and only have the crankshaft sensor. What should I do?
Thanks to my friends.
xiaoyaowangdaren
Re: How to set up the M84 two stroke engine
Postby gtihk on Mon Feb 04, 2019 2:39 pm
We need to know what engine it is.
gtihk
Postby xiaoyaowangdaren on Tue Feb 05, 2019 12:26 pm
It is a simple single-cylinder two-stroke engine without specific model. What is the difference between a two-stroke engine and a four-stroke engine in M84? I want to know how to set parameters in M84.
xiaoyaowangdaren
Postby xiaoyaowangdaren on Sun Feb 10, 2019 1:36 pm
Dear friends, doesn't anyone know how to set it up? Or do you have any information about it? Thank you
xiaoyaowangdaren
Postby David Ferguson on Mon Feb 11, 2019 9:30 am
What does the crank shaft trigger wheel look like? Have you tried using the appropriate Ref/Sync mode for the trigger wheel, and setting the CrIP with a timing light?
Return to M84 ECUs
