The triumphal 675 USES a MAP sensor for the CAM signal
Postby FSC-China on Wed Jan 23, 2019 2:17 pm
I am trying to start my triumph of 675, I will pressure sensors connected to a cylinder CAM signal instead of me, because I don't have the camshaft engine sensors, when it starts to catch caught my REF/SYNC signal figure, SYNC is a voltage change, it seemed very normal, but I'm not in the process of start fuel injection and ignition, my wiring harness is normal, I suspect is wrong with my Settings, but I don't know change the Settings, I'm in a hurry.
Could someone please tell me what I should do, or could you send me a copy of the basic startup data of triumph 675? I would be very grateful.
FSC-China
Return to M84 ECUs
