About REF SYNC Setup
Does anyone know that in the REF SYNC Setup "60: Ducati<48-2/720> and Triumph<24-2/360>", <24-2/360> means that there are two adjacent tooth missing each 24 teeth once/cycle ?
I am trying to start the Triumph 675, but I don't know which mode REF/Sync mode should use, because I have never seen an engine without a SYNC sensor.
Or I should use mode 8, I try to use Mode8, but there is no ignition and no fuel injection in 4-stroke mode, but I use two-stroke mode only ignition does not spray. Now I don't know what to do.
