About REF SYNC Setup
Postby Fitzsun on Mon Jan 21, 2019 1:15 pm
Does anyone know that in the REF SYNC Setup "60: Ducati<48-2/720> and Triumph<24-2/360>", <24-2/360> means that there are two adjacent tooth missing each 24 teeth once/cycle ? :roll:
I am trying to start the Triumph 675, but I don't know which mode REF/Sync mode should use, because I have never seen an engine without a SYNC sensor.
Or I should use mode 8, I try to use Mode8, but there is no ignition and no fuel injection in 4-stroke mode, but I use two-stroke mode only ignition does not spray. Now I don't know what to do.
Fitzsun
Re: About REF SYNC Setup
Postby Auto Sport Elect on Mon Jan 21, 2019 4:37 pm
Yes the teeth are missing next to each other.
On the Ducati the 24-2 chopper spins at half engine speed, on the Triumph it spins are engine speed.
The 675R I was involved with used Mode 65 which used a MAP sensor for sync on start.
I suggest you make direct contact with MoTeC Europe as they have extensive knowledge on this engine and can help you best.
Auto Sport Elect
Postby Fitzsun on Tue Jan 22, 2019 1:43 am
Auto Sport Elect wrote:Yes the teeth are missing next to each other.
Sorry,I can't understand how to use a MAP sensor for sync on start, can you explain in detail?And my Triumph 675 don't have sync sensor.
Fitzsun
Postby David Ferguson on Tue Jan 22, 2019 3:21 am
You connect the output from a single-cylinder MAP sensor to the SYNC signal, then set the voltage thresholds appropriately. This is very common for motorcycle engines. I did this with a KTM V-Twin, and I've seen it with single cylinder Formula Student/FSAE engines.
Postby Auto Sport Elect on Tue Jan 22, 2019 11:09 am
Yes a lot of rules do not allow you to add a sync sensor, so MAP sync is a way around this.
MoTeC Europe were very helpful to me on this bike, but it is their documents to share, so I would contact them directly.
I have attached a ref/sync capture from the bike I worked on.
The MAP Sensor is connected to one runner only, and sync is only required on startup, from there it can continue to run only using the ref sensor.
Triumph 675R Cranking PI 22.2.13.rsc2
Here is a ref/sync capture of one cranking
(64.45 KiB) Downloaded 1158 times
Auto Sport Elect
Return to M84 ECUs
