M84 Idle stepper motor LS1
hi, engine running at 2000 rpm on idle. could this be a setting, mine are
Idle control setup is
proportional gain 4
integral gain 0
derivative gain 1
dead band 50
activate TP 5
Activate ground speed 4
activate rpm 1300
rpm filter 4
air con increase 0
power steering increase 0
Auxiliary Out 5 is set to function 8 : Stepper Idle Speed Control (Aux5 only, uses 6,7,8 also)
Auxiliary output 6 is off
Auxiliary output 7 is off
Auxiliary output 8 is off
what is meant to happen on the test outputs
before the test A34 is earth and A33 is 12V, nothing at A31 and A32
During the test they are all zero, ie no reading
Any ideas on the settings or what to look at
it is a new idle control motor
Tom
proportional gain 4
integral gain 0
derivative gain 1
dead band 50
activate TP 5
activate rpm 1300
rpm filter 4
air con increase 0
Tom
