M84 / ECUManager disconnects with SDL
Hey all,
Just working through the nitty gritty on a new setup.
When I'm using ECU Manager with the M84 connected through UTC, if I flick the SDL on (separate switch), the M84 will intermittently disconnect and reconnect, while showing a low memory error.
Is this normal? I would assume that I cannot connect to both at the same time, however, am I not able to have the dash on while the ECU is connected?
Cheers
Cheers
