Aux Outputs Amps
Aux Outputs Amps
Postby Vlad on Wed Jun 20, 2018 7:11 am
Correct me if i'm wrong, but in the m84 user manual it says that the aux out 1 and 2 can take a max of 7amps ?! I have to wire the vvl solenoid for a sr20vet, and was thinking of controlling it via a relay, because it's on-off...the solenoid eats about 0.8 amps...Should i wire it via a relay ? or directly to an output?
Vlad Pescaru
Vlad
Re: Aux Outputs Amps
Postby Stephen Dean on Thu Jun 21, 2018 4:21 pm
The Aux outputs are designed to operate these sorts of solenoids directly, you do not need a relay.
Return to M84 ECUs
