Hayabusa Barometric Sensor?
Had a good weekend at the races but noticed after tuning at sea level, then racing at ~4300ft elevation that the Lambda went from .85 at sea level to ~.767 range at elevation. We raced anyway and it was fun. I looked in the ECU and the Gen I Hayabusa Atmospheric Pressure Sensor (APS) is connected but it's labeled as "Fuel Pressure" in the ECU on AV4 input and the sensor has a custom table.
Is there a preset config for the stock Hayabusa Atmospheric Pressure Sensor?
When I set AV4 input to read the stock Busa APS, what do I need to do to tell the M84 that I want it to compensate the fuel table for changes in atmospheric pressure? Comp1 in the Fuel Compensations is locked to EGT and Comp2 is locked to User Channel 2 when I right click and select Axis Setup.
It looks like the "Fuel Pressure" compensation is locked to "Fuel Pressure" in the axis setup and that one is AV4 which is actually my Baro sensor on the Busa so maybe I just use that?
We set a new class record at 202.5mph in the dirt! Thinking of how fast we could have been with the Lambda dialed!
