M84 tuning without a dyno - general steps?
To tune the base map without the Lambda sensor from going into closed loop, should I fill the Lambda AIM table with 0's? or turn the Lambda function off in the setup with a 0 (instead of a 2 for wideband)?
Once the base map is good, then I can tune the accel and decel, then the nitrous/fuel at WOT, then populate the Lambda table and the short term trim should be within range.
I won't be able to get on a dyno soon so I've setup an LED indicator on the dash to tell me when I'm at the programmed throttle setting e.g. 10%, 20%, ... I'm using an Aux table to output to the LED based on the TPS input (I think that's Aux 2). Since I won't be on a dyno, I can't really tune the ignition so I'll just be using the stock ignition map.
Does all of this sound generally in the proper order?
Thanks!
Thanks!
