Lambda delay table and rate
What is a method that I may use to determine the lambda delay? I watched the webinar on how to setup closed loop wide band lambda control and I'm not clear on how to make the events happen that I need to then measure the O2 sensor response in i2.
Another question - I'm riding around, logging, then making changes to the fuel map and it's close enough that the bike works well enough. Should I load the lambda AIM table with all 0's so I'm tuning the map without the influence of the closed loop lambda control?
I can't get on a dyno yet.
