Hayabusa PnP Spares connector pinout?
Postby LSR Racer on Tue Apr 17, 2018 7:42 am
On the wiring adapter box for the Gen I plug and play M84 setup, is there a connector pinout available for the Spares connector? I'd like to know which pin is Aux out 6 on the spares and wire up a shift light.
Thanks!
Shane
LSR Racer
Re: Hayabusa PnP Spares connector pinout?
Postby Stephen Dean on Tue Apr 17, 2018 10:16 am
These kits came out of MoTeC US, so I have asked for some information on them.
There is a pinout for the M130 version of the adaptor box, and I do not believe that they would be very different, the pin information can be found in this file.
https://www.milspecwiring.com/assets/images/data/PACKAGES/m130bikepnpkit.pdf
The other option (and one that I would do to valid the information) is to use a multi meter to bell out the pins. Have one probe on A32 and check the pins on the spare connector until you get continuity.
Postby LSR Racer on Wed Apr 18, 2018 5:19 am
Thank you, Stephen. Very helpful and I will take a look with the meter.
LSR Racer
Return to M84 ECUs
