Hayabusa Gen I ref/sync capture - noisy?
Postby LSR Racer on Sat Mar 31, 2018 3:19 pm
This is a crank/start ref/sync capture from my Gen I Hayabusa with stock magnetic cam sensor. I see some noise at 0V in between the pulses. Does that look like an issue?
_Shane
test2.rsc2
(64.45 KiB) Downloaded 866 times
LSR Racer
Re: Hayabusa Gen I ref/sync capture - noisy?
Postby stevieturbo on Wed Apr 04, 2018 8:44 pm
As it looks like you're using rising edge for the trigger given that waveform and the blip would appear to have a falling edge...it probably shouldnt be an issue
But it seems very regular ?
Return to M84 ECUs
