M84 : Test injector flow
Postby acca on Fri Mar 16, 2018 11:14 pm
Hello
I've upgraded my prototype vehicule (Shell Eco Marathon prototype) ECU from M4 to M84
In order to test my injectors, i used the test output function of M4 software with wich i was able to set injection timing, RPM and injection count.
For example, i set 3000 injections at 3000rpm with an injection time of 1000µs then i measured the injected volume with a graduated pipette.
This allowed me to determine cc/µs injected by my injector.
In the M84 software, i have seen the test output function but i can't set injection count .
Is there any other software i could use ? or a workaround.
acca
Re: M84 : Test injector flow
Postby LSR Racer on Sat Mar 17, 2018 2:45 am
It's in the Test Outputs section. You can vary the pulse rate and width to some degree.
LSR Racer
Postby acca on Sat Mar 17, 2018 2:54 am
Yes but i have to stop it manually
I can't set a number of injections in order to inject the same amount of gasoline at each test
acca
Return to M84 ECUs
