Throttle kicker output
Postby Vlad on Sun Feb 04, 2018 6:19 am
I have recently made a stand alone DBW ecu, to work in paralel with other ecu's that do no provide dbw capability. One ofthe features is the als kick, to eliminate rot idle and make the care easyer to drive with the als of. One of the als option in the m84 is switch input and a throttle cicker is used to open the throttle. In the aux outputs i cannot find e function to do this. I would really want the engine ecu to turn on and off the throttle position for the als, as if the temps excede some thresholds, when the ecu turns of the als, to not leave my throttle plate open. How can i output a low signal when the als is on from the motec ?
Thanks, Vlad :)
Vlad Pescaru
Vlad
Return to M84 ECUs
