M84 Hayabusa Gen II to Gen I
I am moving my Gen II M84 PnP setup to my Gen I bike. In the setup, I am changing the Cam sensor over from Hall to Magnetic and choosing a 24-1 ref/sync arrangement. I believe this is option 5. What setting should I be using for the CRIP? It's at 463 with the Hall sensor.
Also, does anyone know the polarity of the Gen I mag sensor? My harness has been moved around so I'm not sure I have polarity correct. The Ref/Sync capture shows a positive/negative cam signal with one polarity and a negative/positive signal with it the other way. I'm not sure which way it should be.
Thanks,
Shane
Thanks,
Shane
