SprinterTRD wrote:Simple Either waste spark ( 2 coils per output ) or add a IEX for 8 ignition outputs
Thanks for your feedback I will chnge the Igntion system to waste spark in waste spark every coil is connected to two cylinder, my qustion In which cylnider each coil are connected ?
You need to connect the cylinders that fire 360 degrees apart for waste spark, the easiest way to work out which cylinders these are is to do a star diagram like this, and use the joined cylinders in waste spark.
Waste Spark.png (7.15 KiB) Viewed 9913 times
Stephen Dean MoTeC Research Centre Melbourne, Australia
