Launch and Traction Control
Postby Marty on Wed Nov 01, 2017 6:28 am
I want to use Launch and Traction Control in M84.I have few questions about set up:
1)For setting the Launch and Traction Control on, I must use only one Digital input?
2)When the Launch and Traction Control is active. The M84 automatically change the control from RPM vs Ground
speed to Slip control?
3)If my car goes slow down below the speed of changing the control (RPM vs Ground speed to Slip control) it the M84 use for traction control Slip control or RPM vs Ground Speed?
4)Can I change the slip setting by some input (e.g. User voltage input)?
5)If I want to use for Wheel speed Measurement optic sensors, how voltage levels must I achieve for proper function?
6)If I want to use Launch and Traction Control and Gear change ignition cut, are you recommend me use TC Mux or the
speed of one drive and one ground wheel is sufficient?
Thank you.
Marty
Return to M84 ECUs
