Unable to change XY values in Aux Table
As the title states, I am unable to change my XY values in an Auxiliary Output (currently set to function 3; Aux table). All I am able to have in my X is RPM and Y is Gear. When I click on "Select" in the Axis setup page, nothing happens. Same for Ctrl-S. The label is blurred out, like that is a set value, even though in the function description it says: "Used to control a PWM or switched device using a 20 x 11 table with user definable axis parameters."
Any ideas? Am I just doing something blatantly wrong? Or is this something that requires some trick?
