Injection & Ignition not working
Following with the previous thread I wrote, the ECU was finally damaged. We've already solve all the "hardware" problems, but now we have some questions.
We have all sensors and actuators property wired, the problem now is that in test outputs, both ignition and injection are working, but not when cranking (neither spark nor injection) .
My thoughts were first about input sensors (we just use TPS and Engine Temperature), so I wired all the main sensors thinking that maybe without one of them the ECU wouldn't allow ignition & injection.
After that (of course without success), I saw in diagnostics errors that MAF, FP, OP and MAP sensors are always in error (even when the channel is enabled and the sensor wired).
Thus, the ref/sync synchronization is also in error. We have a Ref/sync mode 8, without Sync sensor, but curiously the sync sensor is always feeded with 3.86 volts (I read it is a pull-up, but I'm not quite sure if that is correct)
Any hint or idea about this?? Thanks in advance
