Extra Analogue Temp Inputs
PostPosted: Tue Apr 18, 2017 3:07 pm
by jwm
Hi
I have already used AT1-3 for water, oil temp and air temp and had planned to use AT4 and 5 for Gearbox and Diff temps until I discovered these are not analogue inputs as they are described in the pin out list in the manual :(
One option I have is to use a voltage input with a 1k pull up resistor to a 5v supply.
To do this I would need two AV inputs.
I have AV8 available as the User1 and wanted to know which (if any) of the following I could use as the second:
AV3 (MAF)
AV6 (Exhaust Temp)
AV7 (Gear Pos)
None of which I am using.
I was thinking AV6 was the most logical but will having a diff temp input into this channel affect the ECU running or tune (if it can be done) ?
cheers
