How to adjust logging?
Hi all,
I just know this is a total-noob question & the answer will be obvious ... but how do you change what data is logged by the ECU?
The manual seems to say I should go to the Adjust menu, then Data Logging Setup, then choose an item. So I've gone through the things I wanted to log, and selected them.
Later when I use Utilities / Get Logged Data (Ctrl + F8), i2 shows that I haven't logged the stuff I wanted to log.
What'm I doing wrong, should I have performed a File / Send File to ECU (Ctrl + F5) in order to make those logging changes stick?
Ta muchly in advance!
