How to adjust logging?
Postby Forg on Tue Mar 14, 2017 1:21 pm
Hi all,
I just know this is a total-noob question & the answer will be obvious ... but how do you change what data is logged by the ECU?
The manual seems to say I should go to the Adjust menu, then Data Logging Setup, then choose an item. So I've gone through the things I wanted to log, and selected them.
Later when I use Utilities / Get Logged Data (Ctrl + F8), i2 shows that I haven't logged the stuff I wanted to log.
What'm I doing wrong, should I have performed a File / Send File to ECU (Ctrl + F5) in order to make those logging changes stick?
Ta muchly in advance!
Forg
Re: How to adjust logging?
Postby Stephen Dean on Tue Mar 14, 2017 1:35 pm
Hi Forg,
To get the channels to log (maximum of 16) in the M84, you need to change the Value from 0 to the rate that you want the channel to log at, with a maximum rate (hz) of 100. If there is a 0 next to the channel, it will not log. To remove a channel from the log set, you change the value to 0.
When you have made these changes, you have to save the file using Ctrl+S (if connected to the ECU), or Send File to ECU if you do the work off line and then send it to the ECU.
Postby Forg on Tue Mar 14, 2017 4:11 pm
SDean wrote:To get the channels to log (maximum of 16) in the M84, you need to change the Value from 0 to the rate that you want the channel to log at, with a maximum rate (hz) of 100. If there is a 0 next to the channel, it will not log. To remove a channel from the log set, you change the value to 0.
Thanks heaps!
I've just had a play in offline-mode, it seems obvious now you've described it to me. :)
Forg
Return to M84 ECUs
