Ref mode for Bosch system with twin crank sensor
Tue Feb 21, 2017 6:46 pm
by Promap
The project is to install M84 on a beautiful one BMW 635 GpA. I would like not to change the wiring loom and the sensors. But this engine has 2 sensors on the crankshaft. The one on the crown of starter with more than 100 teeth and the other one with only 1 tooth per crank rev. This system was used by Bosch in the 90s.
With the mode 2 and the number of cylinder 36, this 6 cylinders can works with a distributed ignition and a grouped injection? Val
Re: Ref mode for Bosch system with twin crank sensor
Wed Feb 22, 2017 1:29 am
by Promap
Nobody equipped a BMW or Porsche with this trigger system? Or my question is not clear?
Thu Feb 23, 2017 4:51 am
by Rude Engineering
Bonjour Valerie,
You should be able to use Mode 2 (multi tooth) on this. Connect the sync to the sensor with a single tooth and set the number of cylinders to 36. I think there are 116 teeth on the flywheel but you will need to check.
Thu Feb 23, 2017 6:01 am
by Promap
Bonjour Ross ! merci pour ta réponse ! c'est la première fois que j'utilise le forum. Je suis heureux de te trouver.
Hello Ross! Thank you for your answer! It is the first time when I use the forum. I am happy to find you.
Kind regards, Valéry
