The project is to install M84 on a beautiful one BMW 635 GpA. I would like not to change the wiring loom and the sensors. But this engine has 2 sensors on the crankshaft. The one on the crown of starter with more than 100 teeth and the other one with only 1 tooth per crank rev. This system was used by Bosch in the 90s.
With the mode 2 and the number of cylinder 36, this 6 cylinders can works with a distributed ignition and a grouped injection? Val
