Injector signal wires have constant weak ground
I was facing some strange issues with my brand new M84 and after looking at every single configuration I thought of checking the wires physically. When probed the test light on the injector 12v side it tested ok with the ignition ON. When checking the signal line on all the injectors with all of them plugged out, I found a very weak light glowing on the tester when I crank the engine insteak of it doing on - off - on - off it does on - weak - on - weak. I actually wanted to check the voltage so I used the voltmeter and it was reading 12v.
My problem is that the engine is idling at 11~12 afr and if I reduce the number it doesn't fall gradually. After dropping a couple of numbers it suddenly goes from very rich to very lean. For example from 24 to 21 no difference then from 20 to 19.5 the afr jumps down from 11 to 17 and kills the engine.
I changed everything in the fuel section but nothing makes a difference.
I'm now sure that it is this weak current that is causing the injectors to remain partially open. Should my test light glow even a little when key on engine off? It doesn't on other ecus but don't know about Motec. Please explain thanks.
