CAN inputs for boost control, pit lane limit and anti lag.
Pretty simple question, I don't have an ECU to experiment with. I am deciding on the next ECU for my race car and an M84 is generally quite sophisticated enough for me.
The main questions I have are (And I presume I can by my playing around in the ECU manager software)
Can I use a CAN input to pull in a counter from my PDM to set up variable boost levels via a keypad input? Similarly, can I use a CAN input to control the pit lane speed limit function in the ecu and Can I use a similar PDM function to enable and disable anti lag?
If I can do all three of those three via a CAN input then the M84 would cover off all of the functions I need for the foreseeable future.
